Toilet Fill Delay
  • kewpie3
    Toilet Fill Delay
    Here's a new one.
    We've got one of those low-consumption toilets. Works great but it's started doing something kind of strange. Flushes OK, but it doesn't fill right away like it used to. There's a 5 or 10 second delay before the fill begins. Nothing wrong with the fill once it starts - it just takes a long time to start. Is something wrong, or could something go wrong?
    Thanks.
    Sounds like the float is hanging up on something. If its a ball-rod type maybe its hitting against the inside of the tank or if it's a one piece unit, the inverted float may be water bound and needs to drain itself before it drops to open the inlet valve.
