We moved into our house about 10 months ago. We knew when purchasing a sump pump was installed into a basement closet where they had issues with a wet basement (they/we believe it is from a high water table). So thankfully, we have no problems with water in the basement.
The drain was only run to just outside the house-- the pipe is not extended through the yard, to the end of the yard/street.
So, when it empties, the water is pumped out fairly forcefully, and results in the water and mud from a flower bed rushing over/through a wall, and leaving a mess on the driveway.
Is extending the pipe the entire length of the yard (about 30 feet) my only option?
Thanks for the help!
