Leaking Water Heater
  • samshelton
    • Nov 2004
    I have a super-stor water heater model ss-40. There is a drip leaking from the control connection. I've been told I need a new aquastat well. Is this an easy repair to complete or should I get a plumber in. Also there's a wire going into the unit. Is there any electricity in the wire or is it just a temp guage?
    Thanks in advance, Sam
    The super-stor water heaters are classified as external combustion water heaters. They operate by circulating hot water from a heating boiler through a heat exchanger coil in the bottom of the tank.
    The aqua-stat senses the water temperature in the storage tank and regulates the rate of flow from the boiler to control the water temp.
    Although they are extremely high efficiency units with a super long service life, unfortunately everything requires periodic maintence.
    In my estimation changing the aqua-stat is probably a bit more complex than what I would recommend for even an advanced DIY project.
    First of all, unless you are familiar with the temperature/prssure boiling characteristics of water, venting a boiler to atmospheric pressure can be a very dangerous procedure.
    Changing the Aqua-stat is basically a simple task but In order to change the aqua-stat you will need to blow down the boiler and drain the water heater.
    Prior to relighting the boiler you will have to prove the proper water level in the boiler, then insure that the water heater vessel is properly filled and vented.
    In my estimation this is one case where the safe method would be to consult the services of a plumbing & Heating contractor who is familiar with the proper blow down techniques for boilers.
      Lazy - he said aquastat well - isn't this a welded tube inside the tank? What I mean it isn't a wet well. The sensor screws into a dry well.
        There are two types of aquastats that can be used in this application.
        If it is an electromechanical type it may have a dry probe with a thermostat wire to a solenoid valve to regulate the water flow from the boiler. If so, it would be a fairly simple changeout.
        It could also be a mechanical aquastat that works in a similar manner to a thermostatic expansion valve. In that case the probe may still be a dry probe, but the valve is plumbed directly into the supply line and would require opening the supply line to change the valve.
        The post also says he needs to replace the aquastat well. If so, the aquastat well is the probe into the water vessel that creates the chamber for a dry probe. If that is the case, he would have to drain the water vessel to replace the aquastat well.
