Can anyone point out some common problems that may cause extremely low water pressure throughout the entire house?
It is 150+ year old farmhouse, with very poor water supply (source is a private well). The pressure is fairly low on the first floor, with barely a trickle on the second. Replacing the faucets helped a bit, but does not fix the problem. I was told the water pump is fairly new, but also did not fix the problem.
Thanx in advance, I appreciate your insight.
-jOHNNY
-jOHNNY
