My stud finder should be re-labeled to stud and pipe finder. I was trying to hang something in the bathroom and lined it up perfectly with the sanitation PVC pipe. I drilled two perfect holes through the drywall and into the PVC pipe. Holes are about the size of a pencil and pipe is 3.5" diameter.
I was told by friends how difficult this is to fix...cutting the pipe, glue, fitting new pipe around old pipe, etc. I went to the hardware store and the employee told me to use plumber's putty. This will save me lots of time and money, but I want it done right.
Is this the best solution, or should I suck it up and replace the drilled section of pipe? If so, then can someone detail that process and will it make more sense to just pay someone to do this fix?
Thanks!
Thanks!
