removing a strip nut (faucet) HELP !!!!!!!!!!!!!!!
  • leptons
    • Jul 2005
    I am doing home today. I turned off the main water supply. I remove the handle screw with a Philips screwdriver. Lift it up the handle.
    However, I unscrew the packing nut from the faucet body with a locking plier. I have strip the packing nut. After, I try using a 3/4-socket set. It is hardy moving. What should I do?
    Does brass cartridge are more likely to be wear and tear?
    Why do they use brass for compression faucet?
    When should I replace the O-Ring and Washers?
    Do the chlorine in the water eat away the rubber?
    What is it leaking at the base of the faucet?
    In order to provide an answer I would need to know what type of faucett you are working on. Is it a kitchen or bath faucett? single lever or separate hot and cold valves?
