I am installing a washing machine in the basement of a 4-plex. I do not want to break the concrete floor to access the drain. This will be done in a year when the client decides to build a bathroom here. The 4" cast iron main drain/vent that comes from upstairs has a branch for 1-1/2" tubing off of it. It is located 2 to 2-1/2' from the floor. I've already cut off the old 1-1/2" galvanized pipe and replaced it with abs tubing joining them with a rubber coupling (Fernco). This tubing comes from the renovation I did upstairs in the apartment. The washer/dryer from upstairs is to be located in the basement. Can I simply install a "Y" in the branch I mentioned or is it too high. I have heard that the washer pump will overflow the pipe because the branch is too high from the ground. Keep in mind this is a temporary fix (1 year max.).
Craig
Craig
