After following your advice I'm all ready for soldering. My job is to replace the shut-offs on the washer. I've purchased a single valve shutoff. My main question is how do I get the pipe soldered & not get the valve so hot it gets damaged? Do I put a damp rag on it?
Also I know from your instructions to heat the shut-off so the solder draws to it but could you be very specific about the swetting of the single handled laundry shut-off. I also got the 19040 torch head.
Thank you very much.
