Hello group. I just got a house built in 1966 in Annapolis, Maryland. It has 3 full baths. The one on the second floor I had a single handle Sandard anti-scald valve installed. The 2 other bathrooms on the main floor are still stock so when someone in the house flushes a toilet, or opens a fawcet, the temperature changes a great deal. I have access from the basement to all the pipes that go to these bathrooms. My question is: Should I install a valve at the boiler, that way it takes care of the whole house, or should I do it at each bathroom's pipes. Are there advantages from one method to the other? Would you also please be specific of what type of valve to use? This house has a boiler (uses fuel oil), and no water heater.
Thank you for any help you can give me.
