Smelly garbage disposer
  • fred1949
    • Jan 2005
    • 122
    I would like to know what can be done to make the garbage disposer side of a double sink smell better? The other side smells just fine.
    Thank you,
    Fred
    Primarily the odor is a result of food particles caught on the inside of the disposal housing and the cutter wheel. One simple method of cleaning a disposal body is to periodically (about once a week) run a dozen ice cubes through the disposal. You can also sprinkle a little baking soda in the disposal unit and let that sit overnite, the rinse it out in the morning by turning the water on and running the disposal for a few seconds.
    The actual cutting surface of the disposal ginding wheel is made with grooves very similar to a common metal workers file. Running the ice cubes through the unit will clean the grooves, which not only reduces odors but has the end effect of sharpening the cutters.
    • fred1949
      • Jan 2005
      • 122
      Thanks for the info.
