Bath vent
  • sandie
    • Jan 2006
    Bath vent
    I live in a 113 year old 2 story home. It has the original cast iron vent that runs through the upstairs bath. When it is windy outside we get a sewer odor in that bathroom. It is especially strong when the cabinet that hides the pipe is opened. We are preparing to remodel that bath but would like to be sure this is fixed. Any ideas?
  • ABP
    • Jan 2006
    • 55
    If you plan to remodel, then have the pipe checked, it sounds to me as if the pipe is rotted, cracked, has loose or missing packing, or broken. It is simple to repair, just get a fernco coupling the same size as the offending pipe, cut the cast iron pipe out, replace with same size PVC. If you are not familliar with plumbing, then I would sugest having a professional do it as it is hard to cut cast iron smooth, and if you try to knock out what is left above it may come crashing down and cause bodily injury or damage to property. Not only that, but it may be tied into something else above that you do not see.
    If you think a professional is expensive,
    Just see what till you see what an amature will cost you!!
