Is it permissible to install an AAV "in-line" with the horizontal portion of the drain pipe after the p-trap, or does it need to be configured the way you illustrated in an earlier post (see "Moving washer -- need help"). I have a crawl space with lots of head room (basically a basement), that I thought I could just run the standpipe down under the floor before creating the p-trap, then put the AAV over top of the horizontal pipe (see drawing). If this is ok, do I need to use a wye or is a "T" ok to connect the AAV? Also, I think I read somewhere that the standpipe can be 2" diameter, but the horizontal pipe needs to be a minimum of 3" -- is that correct?
Any advice would be greatly appreciated!
