Problem flushing toilet
  • blythesonline
    • Oct 2003
    As I flush my toilet, the water rises slightly in the bowl, swirls around, but doesn't flush away normally. The water slowly drains down to normal height after a minute or so. I've replaced the ballcock and float already. I've plunged until I'm red in the face. Nothing.
    Then I happened to be experimenting and while in the middle of the attempted flush, as the water is spinning around in the bowl, I poured about a gallone of water into the spinning water and it all flushed away normally. So there doesn't seem to be a clog problem.
    The good people at Home Depot suggested I might have a blockage in the exhaust pipe going out through the roof. I tried putting water down the exhaust pipe with a hose, thinking it might clear out the pipe. No apparent change.
    I'd appreciate any suggestions.
    Thanks.
  • Maintenance Man
    • Oct 2003
    • 10
    Hmm this is interesting...
    Now if I'm reading this right you might have whats known as "a slow flush". This is caused by a buildup of limescale in the water channel under the rim of the bowl partially blocking the holes. Get a small mirror and flashlight to inspect the holes if you find limescale in the holes use a small flat bladed screw driver to remove it, careful don't chip the bowel!. If your bowel has a syphon hole (at the bottom of the bowel) check that for buildup as well. Now I'm sorry to say there isn't a magical cure for this problem if the toilet is old and you live in a hard water area you might have to replace it, as the buildup might be beyond help.
    Sorry to be a doomsinger,
    Good luck.
