Shower Drain
  • gyro
    • Jan 2006
    Shower Drain
    I had the plumbing for a half bath roughed in when i built my home.
    I am now wanting to complete it and my question concerns the
    shower drain. It is a two inch pipe flush with the concrete floor in my split
    level home. It comes out the concrete wall and goes about twelve
    inches and connects to the four inch drain. I do not see a trap installed
    in the line and i don't see where i have room to install one. Any
    suggestions?
  • ABP
    • Jan 2006
    • 55
    Would like to help, but do not quite understand the existing pipe layout. Does the pipe that comes out the wall lay on top of the concrete floor and run horizontaly, or is the 2" pipe stubed up (Vertical) through the floor.
    If you think a professional is expensive,
    Just see what till you see what an amature will cost you!!
    • gyro
      • Jan 2006
      I hope i can clarify my problem. After further observation it appears the
      two inch pipe goes straight down approx. ten inches over six inches and
      connects to the three inch pipe coming from the toilet. That pipe goes
      a additional two feet and then goes thru a vertical cement wall into the basement.
      My house being a split level i actually have four levels because
      i have a basement. It then goes twelve inches at a fourty-five degree angle
      and connects to the four inch drain that goes out of the house. I have
      had people say raise up the shower and put a drain under it, but i was
      wondering if i could bust the concrete and put the trap under or in the
      concrete floor? Thanks for the time for your input.
      • ABP
        • Jan 2006
        • 55
        OK, I'm new to this forum and please do not try to enter my scetch in any drawing contest, please! From what I gather, is this what we are looking at (Basicly?) I'm trying to add an attatchment drawn with paint, hope you get it and can understand it, I,m a plumber, not an artist!! Well, the upload manager says my drawing exceded the limits set forth in this forum, so I can not send you the pic. I tell you what, if you want you can email me at my abp@kinex.net and I can go out and dry fit some pvc fittings together, take a digital pic and email it to you and see if this is your layout. I can help, but need to know the layout as I do not mind giving advice, just hate to give the wrong advice. You know what they say,
        When we assume something we make an (A**) out of of (u) and (me) both.
