To find objects up in the trap of a toilet can be a difficult sometimes. Even toile taugers sometimes auger their way around the object.
I remove the toilet and take it outside or in the bathtub, and set the toilet up on blocks, then fill the tank and flush it and see. I have also put a golf ball in the bowl to see if it comes out the bottom. I have had several where it doesn't come out and have found things like toothrbrushes hidden up in the trap that you could not see from the top or the bottom. Then I repeatedly auger and have a 5 gallon pail of water that I keep pouring down the toilet bowl to create a violent turbulance. Besides a golf ball, you could wad up 2 or 3 wet, turd size toilet papers you scrunch up and toss in the bowl. If these make it out the bottom, you have no ovbstruction.
Then you'll know if your problem is downstream.
Also, be sure to check and make sure your toilet bowl is not limed up. carefully examine that 1 inch size hole at the bottom of the toilet bowl, if you have one, and also up under the rim with a mechanics mirror.
