Changing PVC pipes
  • djslacker
    • May 2006
    Changing PVC pipes
    I just moved my washer to another room and I need to change a pipe to adapt to the situation. I need to know what product I need to buy to counteract the PVC glue used to glue the joint.
  • Aurora
    • May 2006
    • 15
    There is no solvent for the PVC cement. The connection is a permanent one since the PVC cement is a solvent which fuses the pipe with the connector. You will have to cut the pipe above and/or below the joint and replace the pipe and joint.
