Repair PVC Pipe
  • stephenmckeown
    • Nov 2003
    Repair PVC Pipe
    The PVC pipe under the sin is leaking, the leak is at the joint where two pipes are connected and glued together. I can't see how to get the joint apart without breaking the pipe. Do I just clean the joint area and apoxy the joint?
    Thanks
    Thank you
    Steve
  • Hube
    • Nov 2003
    • 453
    You could try and reseal it by wiping in more solvent. Are you sure its not ABS ? Is this the trap that is leaking or the verical drop pipe to the trap?. Hube
    • stephenmckeown
      • Nov 2003
      I'm not sure what ABS is, but the pipe that is leaking is the pipe coming from the wall. There is an adapter with theards cemented to it and the leak is where the adapter is cemented onto the pipe from the wall.
      I'm being told that I can try to reseal it or I have to cut the pipe off and replace it? Is this true?
      Thanks
      Steve
      Thank you
      Steve
      • Hube
        • Nov 2003
        • 453
        Is this leak in the DRAIN pipe.? or an supply line?.. The DRAIN pipe is usually 1- 1/2" in diam. and is a black, plastic material.Normally it is ABS material. You can cut the whole trap and pipe out and replace it for less than $ 15, and about an hours time. Hube
