I'm trying to decide on the height for my kitchen stub out. Not sure if I will be getting a deep sink or a normal size so I want to plan the stub out for all options. The lowest I haved heard was at 14 inches. Any opinions on stub out height? Thanks.
Recommendations for kitchen stub out
Typically we make the waist arm at 16" to 18" unless there is a specific reason such as a deep sink, on the other hand, the code will allow the tailpiece from the sink to be a maximum of 24" vertical from the elevation of the drain opening to the water level in the trap. In most instances 14" would be adequate for a deep sink, but i would measure the cabinet height, deduct the sink depth then deduct another 6" or even more if there is going to be a disposal on the deep sink. -
Well the sink is a single bowl 9 inches deep undermount and probably we'll add a disposal. I forgot to ask if the stubout is better placed in the center of the sink or to a side if there is a disposal involved? Or is this not too important? Thanks.Comment
