Copper pipes incontact with other metals??
  • timfogl
    • Dec 2003
    • 9
    Currently finishing my basement. In the process of insulating and covering things up I have noted that in a few instances copper pipes running in the floor joists are in contact with galvanized sheet metal parts in the ducts and plenum of the furnace. Should I be concerned about trying to separate these if possible? Prompt replies would be appreciated...work stopped for this issue....thanks in advance...
    Tim
  • Jimmer
    • Oct 2003
    • 274
    Tim,
    Welcome to the forum.
    I would separate the two dissimilar metals. There is a reaction between copper and galvanized leaving the galvanized less protected. Also though I would be concerned about noise being created or conducted from one to the other. Rubber pads or something similiar should work.
    Good luck, Jim
    • timfogl
      • Dec 2003
      • 9
      Thanks Jim, will see if I can sqeeze something between the two...
      Tim
      • handyhecx
        • Jun 2004
        • 8
        Hi,
        I just remodel my basement bathroom. I use Oatey's Pipe Support System Clamps. There are various types. Check out the link. I used the standard type and they were great.
        Good luck,
        Handyhecx
          How about those insulating sleeves that you cover water pipes with? Would prevent any condensate from messing up all your ceiling work, as well as insulate from other metals.....
