Septic system clogging
  • Skooter4
    • May 2008
    Has anyone had experience with septic system additives? I have found a few treatments that look like a solution to my clogged drainfield but not sure what to go with.
    Thanks
    Septic system...
    Unless you had the tank pumped AND disinfected, it's not likely you need any bacteria additives to help the breakdown of the waste. All that's needed in there is already in there. Am I correct in assuming that the drain field is clogged rather than the tank? Could you give us more detail on what the problem(s) is? There are several ways of solving tank, as well as field, problems.
      from the septic tank to the first distribution hub it can be snaked out. from other distribution hubs, you'll need to dig up the first hub and see where the other lines go then snake them out. use RID-X for anerobic breakdown in your tank.
