Not sure that this is a plumbing problem, but don't know where else to post. It does however involve water.
I am asking for my daughter who is at a complete loss for solutions, and called dad for help. The house is 18 years old, poured concrete foundation and poured cement floor. Lots of rain this year and lo and behold, she has water entering the house where the floor meets the concrete wall on the rear wall. She has removed the wallboard about 6 ft wide now, and vapor barrier and insulation up to a small window, and found no cracks in the wall where water might have come in. She did find water on the floor, between the 2x4 bottom plate and the foundation wall. At times the water makes its way out into the living area. The bottom plate is beginning to be moldy and will need to be replaced. There is evidence of efflorescence as well. After contacting the municipal inspectors, they advised that the municipal building code for a house that age dictates that there is a weeping tile pipe drain around the perimeter, and is usually connected to a sump pump. She has a sump pump (on the front wall) but is has not run in years.
A contractor she contacted today, wants to cut the floor at that wall, by first cutting the wall studs at 48" high, then cutting a trench in the basement floor by removing 18" of the floor. He will then dig this out, install 12" of gravel, lay a perforated PVC pipe that slopes and drains the length of the of the room to a 2 cubic foot hole filled with gravel. Then he will cement over all of the floor that he has cut away and the room can be refinished.
My question is, should not the outside wall be dug up and new weeping tile pipe drain be installed? New crushed stone be added below the weeping tile pipe drain, and have that drain slope away from the house into the backyard which is not very big (20 ft. deep) and plagued with an underground spring? Possibly have it drain into a "well" of crushed stone? I also feel that an alternative to digging is that she needs to remove the deck on that rear wall and add soil to ensure that there is an adequate slope away from the foundation to help move rain water away from the foundation.
She has 2 young kids and 2 of the above options can be quite costly, so dad taking up the deck and adding soil for better drainage is the preferred route. Am I on the right track here, or must the rear wall be dug up, or is the contractor's approach the best way.
