WATTS instant hot water circulating system
  • sharond444
    • Oct 2008
    After a little more than a year (after warranty is out) the sensor valves are not working correctly. Turning on the cold water only brought hot water.
    WATTS indicated the entire sensor valve unit (have two) would need replacement at $34 each. I removed the system and thought about selling it but only the pump seems to be worth anything. Is there not a way to repair the sensor valve unit?
    WATTS #500800 hot water recirculating system.
    Sensor valve unit #367010.
    Thanks for your advice.
