Toilet blues
  • M. Hall
    • Jan 2003
    Toilet blues
    My (assumed to be) 10 year old Kohler toilets is
    giving me fits. It has no pressure, won't fill the
    bowl(unless I hold the float down, and overfill
    the overflow tube). I've snaked it (scratching
    the porcelain in the process), and the jet holes
    are clean. The float and flapper appear to be
    working correctly, but it only drains about 1/3
    of the way when flushing normally. Holding the
    lever down doesn't help with the lack of flushing
    power. I have to plunger it after almost every
    use. Any ideas????
  • handyandy
    • Sep 2002
    • 205
    I don't think it is a drain problem, instead I think it has more to do with the intake. Have you replaced the valve and balloon?
    • M. Hall
      • Jan 2003
      Well, it has the valve, but not a ball-a float.
      What indicates these are defective???
      • Todd
        • Oct 2002
        • 81
        It sounds like you may need to snake it again. The water not filling the bowl is troublesome. Turn off the valve and inspect everything... It could be hard water build-up. I'll think about it some more and please report back if it doesn't get better.
        Todd
        • Lee
          • Feb 2003
          If you dont have the old style ball-cock with the arm and ball, then you most likely have a 200a or 400a fluidmaster. It may be defective. the line that goes from the fluidmaster into the "overflow tube" is what fills the bowl. If there is no water coming from this line, replace the fluidmaster. If the line has kinked or came out of the flushvalve aka overflow tube, then fix that. You will not get a good flush without a bowl full of water to start with. The fluidmaster is responsible for putting water into the bowl through the flushvalve
          Lee
