Softening caulk/putty
  • pyramid
    • Mar 2009
    • 6
    I didn't know where else to post this, so if it needs to be moved so be it.
    Some years ago I installed two plastic splash guards at each end of the tub surround. These were held in place by a hard setting caulk/adhesive.
    Well, the guards are removed and it's time to remove the old caulk. I was hoping for some chemical approach which would soften the caulk and yet not damage the tub material.
    I've tried using a hair dryer to soften this stuff with heat but it takes a lonnnnng time to get anywhere.
    Any ideas?
  • Redwood
    • Feb 2009
    • 512
    If we knew exactly what adhesive caulk was used there may be a solvent of some type that could be recommended. Until then keep scraping. I usually use Phenoseal or, Polyseamseal in these applications. They can be removed faily easily but bond well.
    Now I can Plumb!
    • pyramid
      • Mar 2009
      • 6
      That's the problem, it was long enough ago that I don't remember even where the stuff was bought - possibly one of those junk mail catalogs for the homeowner. I was just hoping there might be some general purpose item out there that won't eat the tub material.
      Thanks for the reply.
        try a bit of lacquer thinner or acetone on a part of the tub that don't show. if the tub doesn't dull down or get soft then I guess its ok to try on the cement/caulk.
        • jnaas2
          • Feb 2008
          • 213
          Denatured alcohol does a good job of softening up old caulk and making it easier to remove with a scraper and also removes soap scum so the new caulk will bond good. Redwood Ive never heard of phenoeseal before where do you get it and is it good
          • Redwood
            • Feb 2009
            • 512
            Around here lots of places have it.
            It's cheap and it works!
            2 plus's in my book!
            PHENOSEAL Caulks and Sealants
            Polyseamseal | The Biggest Name in Caulk
            I really like the clean up with water caulks.
            I seldom use any silicone rtv product.
            Now I can Plumb!
            • jnaas2
              • Feb 2008
              • 213
              Thanks for the Info
              • pyramid
                • Mar 2009
                • 6
                I have some alcohol around so I tried it. I wouldn't have thought of that. Thanks!
                It does work, albeit somewhat slowly. I'm going to try to come up with some way to soak the stuff for awhile to save some labor. I'm thinking a strip of rag covered with saran or somesuch to keep the alcohol from evaporating too quickly.
                I also have some acetone (nail polish remover) I'm going to try.
                • jnaas2
                  • Feb 2008
                  • 213
                  Tha acetone can eat some tub surrounds that are made of plastic or acrylic so do a test area to make sure. If its porcelain tub and ceramic tile you shouldnt have a problem
                  • pyramid
                    • Mar 2009
                    • 6
                    That's why I tried the alcohol first. Besides, acetone is just so repulsively potent. And, in a small space like a bathroom it could be unhealthy - not that alcohol is entirely benign.
                    • pyramid
                      • Mar 2009
                      • 6
                      Well, the alcohol works well enough that I'm not going to chance the acetone, since the material is acrylic/plastic.
                      It'll take awhile but, what I've been doing is wetting a strip of paper towel with denatured alcohol and laying it on the caulk. On top of this I place a strip of aluminum foil to keep the alcohol from evaporating and finally, on top of that a wet washcloth to keep the towel pressed against the caulk. It'll be interesting to devise some way of doing this on the vertical parts at each end.
                      Anyhow, an hour of this treatment seems to work well but two works better. It returns the caulk almost to its initial gooey state - soft enough to be wiped off with a kleenex.
                      To speed things along I took off some of the heaviest parts with a rotary file chucked into an electric drill. Tried the Dremel tool too and that seemed to work better - more control. This requires serious focus though to keep the tool from jumping and hitting or damaging the tub finish.
                      Thanks again for the assist.
                      • pyramid
                        • Mar 2009
                        • 6
                        Well, only a few more treatments and that old, nasty caulk will be history.
                        Thanks to all who took the time to respond!
