cold water from the hot side of the faucet
  • bigcountry1860
    • Mar 2009
    Hello,
    I just moved in to a "new to me" older house built in the 70's, problem is with the bathroom sink water supply....the faucet it a delta single knob, and when I turn on the hot water i get cold ( the cold works fine ), I turned off both valves under the sink and tried them 1 at a time both are sending plenty of water its just always cold, the hot water in the rest of the house works great, any ideas, thanks in advance
  • Redwood
    • Feb 2009
    • 512
    How's the tub/shower in the same bath?
    Any single handle Moen or, Mixet valves in the equation?
    Have you got a hot recirculation system?
    Now I can Plumb!
    • bigcountry1860
      • Mar 2009
      the tub along with all othe hot water outlets in the house work fine.....yes the tub has a single knob delta faucet
      • Redwood
        • Feb 2009
        • 512
        What I am suspecting is a hot/cold cross connection where the cold flow wins and that is all that gets supplied to that faucet.
        There are a few possibilities among them Moen single handle valves, improperly functioning hot water recirculation loops, or even a slop sink where the hot and cold water can be left on and the water turner off at the spout.
        Now I can Plumb!
