Laundry tub pump problem
  • rennyboy
    • Feb 2007
    • 34
    I have a basement where my washer and dryer are along with the heating unit. There is a laundry tub that the washer water dumps into and the water from the ac and humidifier. The main sewer is about 6 ft higher than the tub. The drain line of the tub has a pump connected underneath it that looks a little like an old style tea kettle, it's part cast iron and shuts off and turns on at certain levels of water. The water than flows from a pipe connected to it up to the sewer. Lately it has been going out very very slowly. I snaked out the sewer but noticed that the water going out was not pumping up fast at all. The water in the tub has a nice whirlpool like as if it was going fast, but it seems like it is just spinning. Anyone have any solutions for me or where I can purchase another pump like this and about what it would cost for the pump? I have not seen any of these in the local supply stores. Thanks in advance for any and all help
    look for an ejector pump. go to ww grainger supply.
    • Redwood
      • Feb 2009
      • 512
      Have you got any info on this "tea kettle" pump maybe a pic would help..
      Now I can Plumb!
      • rennyboy
        • Feb 2007
        • 34
        I am going to take and post a pic of the pump for future use. The problem wasn't the pump after all. The pvc line going from the tub to the main was full of lint and crud, removed the pvc and replace w/new pvc and new check valve and all working good.
