Hey everybody,
I'm not sure what's going on with my toilet. A week ago my toilet developed a slow leak. I determined that the flapper was warped, so I went out and got a fluidmaster 'universal' flapper that was identical to the pre-existing one in the toilet. I swapped out the old flapper for the new one, adjusting the pull chain, and gave it an inagural flush. And everything worked - that is there was no more leak.
The toilet went through a complete flush, however the final resting water level in the bowl is *much* lower than it used to be. Subsequent flushes do nothing to raise the water level. It appears that the new flapper falls closed far faster than the old one, letting far less water into the bowl (after the flush).
A friend said that the newer flappers are made with different rubber that doesn't hold air as well, so it falls closed faster. I'm not sure that I buy that. Did I get the wrong part, or am I missing something here...
(Just for info, my toilet has a ballcock flush valve.)
Thanks.
Thanks.
