Any clue on how to remove a two-handle Kohler shower cartridge that does not have the captive nut to unscrew?? This is a model with plastic stem extensions that screw into internal threads in the brass casting.
Kohler 2-handle shower cartridge removal
Trust me!
It's a little deeper into the wall but they do have a nut surface to remove the stems.
Kohler Plumbing
Make sure you replace the seat as well.I stayed at a Holiday Inn Express last night.
Now I can Plumb!
Thanks, but I think my cartridge is different. It's the type with a square handle stem instead of the splined one in your image. Mine looks like the 7661 type of cartridge. The part of mine that your image has the packing nut on is plastic and the stem inside that is plastic. The operating stem sticking out of the cartridge is plastic and is square, not splined. The hole left in the shower liner is too small to allow a socket to go over the brass part with internal threads into which the plastic stem extender screws. I can neither see nor feel any nut-like flats there. Is there possibly a cartridge retainer similar to what Moen uses?
I thought you would find it there...I stayed at a Holiday Inn Express last night.
Now I can Plumb!
