Laundry Tub Faucet repair for non- handyman.
  • deke56
    • Apr 2008
    I have an old (1970) style faucet in my basement laundry tub. Last night after cleaning up some painting materials, the hot water faucet shutoff will not completely shut off the hot water. It will only turn so far and then just spins. I've had to shut off the cold water input to my hot water heater to stop the leak.The faucet is a wheel style with a screw in the middle. How do I fix this.
  • Redwood
    • Feb 2009
    • 512
    Remove the handle then remove the stem and see what it needs.
    It may just need a new washer. Replace the seat as well.
    Now I can Plumb!
    • deke56
      • Apr 2008
      Thanks for the info. I'm not really good at this stuff. Is the hot water tank water input shut off while doing this OK, or do I need to shut off the main water into the house. Also what is a seat?
      • Redwood
        • Feb 2009
        • 512
        You should have 2 valves under the sink you can shut off.
        After removing the handle and unscrewing the stem...
        stem
        Still inside the faucet body there is a seat. Note on some of the cheaper brands they are not removable. The seat unscrews with a special wrench set using the right one to fit it... It is best to replace them but smothing them with sandpaper works well in a pinch. The water leaking past the washer erodes the seat and if the seat is not replaced or, resurfaced it will be rough and ruin the new washer when you install it. The seat if replaced must be a perfect match or it may ruin the faucet.
        seat **********************************seat wrench set
        Now I can Plumb!
        • deke56
          • Apr 2008
          Redwood
          Thanks for the information. I will give it a try tonight. The only other thing is that are no shut off valves under the sink. Am I OK with just the water heater valve being shut off or should I shut of the main water.
          • Redwood
            • Feb 2009
            • 512
            Tracing the supply lines back there is no means of isolation ?
            I'd change that!
            Usually that situation is only found on bathtub/showers...
            If you are doing both sides then hit the main.
            If you are only doing the hot then usually at the water heater is okay.
            Now I can Plumb!
              if you have a real old faucet then the seats are not removable. a plumbing shop or box store will have a faucet seat grinder kit. basically its a tee handle with a serrated cutter on the bottom. it goes into the faucet with the gland nut to keep it centered and you just cut the seat flat.
