I live in an apt in NYC and I'm having a problem flushing my toliet. It started not too long ago where it would flush properly every other flush and now I have to dump water to get a flush. The toliet doesn't have a tank just a pipe that goes into the wall. Any suggestions on what may be causing this or how I could fix it?
Poor Flushing Toliet
I would consult the building management. Inside the wall there is a flushometer that either they will fix for you or, they will have to provide access for your plumber. In any case talk to them first.I stayed at a Holiday Inn Express last night.
Now I can Plumb!
Did you know some Redwood Pipe is still in service today. -
You might also want to check the small holes under the rim of your toilet, they provide much of the water flow that causes flushing to occur.
HandymanTrainerComment
