We notice a sulfur/sewage smell coming throughout our homes vents whenever we run upstairs sinks or toilets or the blower fan comes on. After which, we smell almost a musty smell.
It typically will only happen in the winter (as soon as we turn the A/C off)
Placing water into the drain in our Utility Closet doesn't seem to always work..in fact, we got in the habit of doing it everyday, and it seemed to have made things worse.
We at times will also smell it coming through our sinks--running water down the drain seems to help this problem.
We aren't sure if it is a plumbing problem or a HVAC problem. The only thing we know is that we want a long term solution to eliminate this odor. As you can imagine, when we have guests and it all of a sudden decides to present itself...it isn't pleasant. Also replicating the smell for a technician is proving to be difficult.
We live in a 3 story townhouse on a slab foundation in Northern Virginia. Built in early 2000's. Our utility closet is on the bottom level with a sealed door opening to the garage. It is vented with two vents into our basement bottom level. AT times, we can smell the smell coming from the closet through these vents (and if we go in the closet) Some of our other neighbors with different models have the same problem.
Any and all help would be appreciated!
