Water pressure surging
  • Gilbert
    • Feb 2003
    Hello,
    I am having a problem with my water pressure surging. I have a well with a holding tank in my basement. When the water is running my pump turns on for a couple of seconds then turns off, then turns on, then turns off..... I am thinking that it may be a problem with the pressure in the holding tank. Is there a standard method of setting up the holding tank that I could try. There is a valve for compressed air, but I don't know how much or at what point do I measure the pressure. I am cuurently layed off from my job so I can't really afford a plumber. If you think you can help please post.
    Thank you,
    Gilbert
  • Gilbert
    • Feb 2003
    Sorry about the 2nd post. I am getting some kind of error message. Seems not to be my week(:
    • admin
      Administrator
      • Feb 2001
      • 93
      What error message did you get?
      • Lee
        • Feb 2003
        Gilber, sounds like your bladder tank ( what you are calling the holding tank) has a busted bladder. If you get water from the valve stem when trying to check the air pressure, then the bladder is busted and you need a new tank.
        Lee
        • REBECCA
          • May 2003
          Lee
