Delta Palo Faucet Leaking when On
  • jtfoxman
    • Jan 2005
    • 150
    Hi all!
    I have a 2 year old Delta kitchen faucet with the faucet that doubles as the sprayer wand. It looks exactly like the Palo 467 SD version but it does not have the integrated supply lines, it may be an older version of the Palo or a Talbott. It does not have the center mounting nut just the 2 side mounting nuts. It has some type of large metal clip that holds the center part on instead of the nut Recently not sure when it happened it started to leak when turned on and nobody noticed. I noticed the leak tonight, it was leaking around the base of the faucet a bit and shooting out under the sink only when turned on. I started to disassemble it and found that the hose that carries the water up to the wand/faucet was lose at the wand connection, a couple turns and it stopped the leak.
    I am wandering how could this occur? Delta says no tape or pipe dope at this connection so how can I stop this from occuring again or do I have to keep checking on it every now and then? Is this also a common occurence with these types of faucets?
    After I reassembled everything now one of my braided hoses that connects to the sink is leaking just a little bit so i have to fix that in the morning. Any tips on how tight to make this connection with no leaks?
    Thanks everyone!
    Jtfoxman
  • Redwood
    • Feb 2009
    • 512
    All of those connections are sealed with a rubber washer. Unfortunately the supply lines do not do well with being taken apart and reassembled.
    I would recommend replacement of the supply line if it is leaking.
    Now I can Plumb!
    • jtfoxman
      • Jan 2005
      • 150
      Thanks for the advice Redwood. I finally got the supply line leak free. I just backed off of it a little bit and it stopped. If it starts to leak again I'll purchase some new supply lines.
      Anyone know anything about the faucet?
      Jtfoxman
      • Redwood
        • Feb 2009
        • 512
        I thought you solved that by tightening the connection.
        About it repeatedly loosening to some degree it's the nature of the beast as it is a constantly moved connection and subjected to stress.
        I would give it a bit extra on the tightening...
        Now I can Plumb!
