I'm replacing my tub/shower faucet and valves. Trying to anyway. In order to get the valve off (single handle, cross piece), I need to remove the couplers from the water supply lines. These are very difficult to turn (using a medium sized pipe wrench), in fact the couplers don't turn at all, I end up twisting the connecting pipes. I've added Liquid Wrench with no success. Any other products or tools? I guess the next step would be cutting them off – I'd probably let a pro do that. Just wondering if I've exhausted my options.
Very stuck pipes
Rob,
Welcome to the forum.
If you remove any rubber or nylon parts from the valves you could then use a torch to heat the coupling. If you heat the female side it should expand quicker and get larger.... allowing you to loosen it.
Good luck, Jim
'Just a handyman trying to help''Just a handyman trying to help'
If you think there's still some rubber/plastic part in there, or if it's not a good place to get a torch into, use Parts Blaster. Usually available at an auto parts store like Murray's. This stuff is super! Squirt only a bit on the fitting and then slightly tighten the fitting, then put a light pressure to loosen. Let it set for 15/20 minutes, and then the tighten/loosen again. Keep trying the tighten/loosen act several times until it starts working loose. Now, if that doesn't work, then it IS smoke wrench time![8D]
I went to the auto parts store, but they were out of PB. Since the hardware store is right next door, I went in and got the torch. I admit, I was a little intimidated by it at first, but it turned out to be simple to use and worked great. Thanks guys.
