In August/September 2009 I had a discussion with members of the Home Repair Forum concerning a problem I had encountered with the flushing of my commodes. I was posting under name of Sunshine -
I believed I had the problem resolved until about three months ago- I once again had water all over my primary bathroom floor. Since then I have NOT used that commode.
I have been "stewing" about this - trying to decide what to do next.
This past Wednesday, May 25th, I drove down to the Lowe's store to see what they might have in an alternate commode. My query to the sales person - I wanted to know if "they" made a commode that, when flushed, would drop the contents directly to the septic line. I wanted a commode that did NOT have such as that "S" for the contents to go through. He told me that the "S" is a requirement (by someone) because that is where the trap is located. Well, that is the first time I knew there was any such mechanism down there.
O.K. I told him that I am considering replacing a Universal Ruddle #4490 that had been put in place in 1996 - and I explained my concern. He told me that apparently that was/is NOT a desirable unit. He said any of the newer toilets will flush better than the Universal Ruddle. He talked about different toilets that I might consider - mostly the Kohler - I told him that I would get back to him.
I decided to stop at the Home Depot - same reason. I don't believe I told that sales person the entire story, but the discussion let to him suggesting that I consider a "pressure assisted toilet" and mentioned the name "Sloan Flushmate".
They did not have any that I could see, but he mentioned the American Standard Cadet and the Kohler Highline. They could order either for me.
I thanked him for his help - I would get back to him.
So, yesterday, I spent an hour or two at the computer to see what I could find.
My concerns: apparently this is a one piece unit - using 1.6 gpf water and seemed to be a total of 29" in depth - which is at least 4.5" longer than my current commode combination. The current bolts (to the floor) are located 12" from the wall and I have to wonder if the elongated unit would allow the use of those holes.
I found that the Consumer Reports seems to indicate that the American Standard Compact Cadet Flo Wise 2403.128 is "best" in choice. That is uses the Sloan Flushmate system - and from what I read - that sounds interesting.
I do understand that, when flushed, this system is noisier than a "normal" toilet. I also have to wonder if my "work person" could actually put this unit in place. No matter, I feel that the Home Depot would find someone to "install" the unit.
On Saturday, May 29, 2010 - I returned to the computer and did some additional searching and found that the American Standard Cadet Flo Wise 2403-128 covered by the Consumers Reports is NOT the unit that I was looking for.
This morning: I found the American Standard 2366.100.020 which DOES use the Sloan Flushmate III system - it is a "round front two piece toilet" - and mentions a "12 inch rough".
This morning, before preparing this entry - I once again got into a search specifically for the Kohler Highline that the sales person from the Home Depot had mentioned - and, from what I could find - that seems to use something referred to as a "pressure Lite" system - I don't know if that is the same as the Sloan Flushmate system.
I did find a Kohler K3492 Highline Pressure LIte (two piece) elongated toilet-it uses a different
"pressure assisted flushing system" - the length is 30 1/8" and mentions a "12" rough".
I would appreciate any feedlback - good or bad. Thank you.
