NOT ENOUGH HOT WATER TO SHOWER
  • Utilitygirl
    • Feb 2004
    • 5
    I HAVE NOTICED WITH MY CUSTOMERS THAT WHEN THEY COMPLAIN ABOUT A GAS PROBLEM IT TURNS OUT THAT THEY ONLY HAVE A COMPLAINT WITH THE WATER HEATER NOT SUPPLYING ENOUGH TO ONE BATH ROOM. IF THE DIP TUBE WAS DEFECTIVE THEY WOULD NOT GET ENOUGH HOT WATER. HOT WATER IS GETTING THERE IF RUNNING ONLY HOT,SO IT CAN'T BE THE DIP TUBE,RIGHT? I BELIEVE IT HAS DO BE THE DIVERTER IN THE FIXTURE NOT MIXING THE CORRECT AMOUNT OF HOT AND COLD TO MAKE IT A WARMER TEMP. DOES THIS SOUND RIGHT? I USUALLY FIND THIS IN THE ONE HANDLE SYSTEM.[8D]
    Utilitygirl
