I have a white kitchen sink that is made of (LG Composite) material and I need to replace the existing white Insinkerator Garbage disposal flange with a new white one (Not Stainless). What should I use to seal the white flange to white sink.. Plumbers putty is a no-no... White silicone??
Insinkerator Garbage Disposal Flange
For sealing a white Insinkerator garbage disposal flange to a white LG Composite kitchen sink, using white silicone is a great choice. Plumber's putty is not recommended for composite sinks as it can potentially cause damage over time. White silicone caulk will create a strong, waterproof seal and match the color of your sink. Simply clean the area thoroughly, apply the silicone around the sink flange, and press it into place. Allow it to cure according to the manufacturer's instructions before using the sink. This will ensure a secure and clean-looking installation.
