The brine tank on my fleck 5600 water softener slowly fills during service mode. The result is an overflow during the brine tank fill cycle step (there is no float in this unit). Ideas?
brine tank slowly fills in service mode; fleck 5600
Hi! It sounds like your Fleck 5600 water softener’s brine tank is overfilling during the brine fill cycle, likely due to slow or continuous water flow. Here are a few things you might check:
1. **Brine Line Blockages**: Inspect the brine line for any clogs or restrictions that could be affecting the flow. Cleaning or replacing the line might resolve the issue.
2. **Brine Valve**: Check if the brine valve is functioning properly. It should open and close correctly during the fill cycle. If it's malfunctioning, it could cause improper water flow.
3. **Air Check Valve**: If your system has an air check valve, ensure it's working correctly. This valve prevents brine from flowing back into the water supply, and a malfunction could lead to overfilling.
4. **Brine Tank Position and Debris**: Make sure there’s no debris or buildup affecting the brine tank. Although your unit doesn't have a float, ensure the tank is positioned correctly and not causing any overflow issues.
5. **Regeneration Cycle Settings**: Double-check the settings on your Fleck 5600 to make sure they’re set correctly for your system. Incorrect settings might lead to excessive water entering the brine tank.
6. **Drain Line**: Verify that the drain line isn’t kinked or blocked. Proper drainage is crucial for the correct operation of the brine tank.
If these checks don’t solve the problem, referring to the user manual or getting in touch with a professional might be the best way to address the issue.
