Best practices for winterizing plumbing in cold climates
  • Annahmed
    • 223
    As winter approaches, what steps should be taken to prevent frozen pipes, and are there specific products or techniques that work best?
    Thanks for your help!
  • TinyTool
    • 357
    Hi!
    Keeping your pipes from freezing is all about keeping them warm and the water moving. Here's how to do it:
    Wrap 'em up: Put foam sleeves around pipes in cold spots like attics and basements. It's like giving your pipes a warm jacket. Use zip ties to keep the foam snug on the pipes.
    Seal the cracks: Look for tiny holes where cold air sneaks in near pipes. Fill these gaps with caulk or foam spray. Don't forget to check around where pipes go through walls - these spots are often missed.
    Keep the heat on: Even if you're away, keep your house at least 55°F. Open cabinet doors under sinks to let warm air reach the pipes.
    Let it drip: When it's super cold, let faucets drip a bit. Moving water is harder to freeze. A trickle the size of a pencil lead is enough.
    Outdoors matters: Unhook garden hoses and turn off water to outside faucets. Use foam covers on outdoor faucets for extra protection.
    Smart gadgets: Consider using WiFi temperature sensors in cold spots. They'll tell your phone if it's getting too cold. Put one in your attic - it's often colder than you think up there.
    Know your pipes: Figure out where your main water shutoff valve is. If a pipe does burst, you'll need to turn it off fast. Put a tag on it so anyone can find it in a pinch.
    Warm it up: For problem pipes, try heat tape. It's like an electric blanket for your pipes. Just make sure to follow the instructions carefully - safety first!
    Any of these tips you want me to explain more? Or do you have a tricky spot in your house you're worried about?​
    • Annahmed
      • 223
      Ah no Tinytool, thank you for the tips!
