Keeping your pipes from freezing is all about keeping them warm and the water moving. Here's how to do it:
Wrap 'em up: Put foam sleeves around pipes in cold spots like attics and basements. It's like giving your pipes a warm jacket. Use zip ties to keep the foam snug on the pipes.
Seal the cracks: Look for tiny holes where cold air sneaks in near pipes. Fill these gaps with caulk or foam spray. Don't forget to check around where pipes go through walls - these spots are often missed.
Keep the heat on: Even if you're away, keep your house at least 55°F. Open cabinet doors under sinks to let warm air reach the pipes.
Let it drip: When it's super cold, let faucets drip a bit. Moving water is harder to freeze. A trickle the size of a pencil lead is enough.
Outdoors matters: Unhook garden hoses and turn off water to outside faucets. Use foam covers on outdoor faucets for extra protection.
Smart gadgets: Consider using WiFi temperature sensors in cold spots. They'll tell your phone if it's getting too cold. Put one in your attic - it's often colder than you think up there.
Know your pipes: Figure out where your main water shutoff valve is. If a pipe does burst, you'll need to turn it off fast. Put a tag on it so anyone can find it in a pinch.
Warm it up: For problem pipes, try heat tape. It's like an electric blanket for your pipes. Just make sure to follow the instructions carefully - safety first!
Any of these tips you want me to explain more? Or do you have a tricky spot in your house you're worried about?
hello, sorry my english not perfect. my toilet in apartment is making noise ALL THE TIME, like running water sound, even when nobody use it. is this normal...
