Keeping outdoor pipes warm
  • Downaski
    • 409
    Hi everyone!
    Is there any way to keep my outdoor plumbing pipes warm in winter? The water from the taps is coming out too cold.
  • TinyTool
    • 357
    Hi there!
    One simple way is to wrap the exposed pipes with foam pipe insulation, which is affordable and easy to install. For colder climates, using heat tape or heat cables can be even more effective, as these plug into an outlet and keep the pipes warm. Be sure to follow the manufacturer’s instructions for safety. Additionally, covering outdoor faucets with insulated covers or even wrapping them with a thick towel secured by duct tape can provide some extra warmth. If the temperatures drop really low, allowing the faucet to drip slightly can keep the water moving, which reduces the risk of freezing.
    Another thing to check is whether garden hoses are disconnected—leaving a hose attached can cause freezing in the faucet and pipes. If your pipes are fully exposed to the weather, adding a simple shelter, like a wooden box or a temporary windbreak, can also help insulate them from the wind chill. Are your pipes fully exposed, or are they under some form of cover, like a patio or deck? Knowing this could help narrow down the best approach for your situation. Let me know how it goes!
    • Downaski
      • 409
      Thanks for the advice! I am actually asking about a few pipes along the outside wall of the house, and they're pretty exposed. Would foam insulation still work in this case, or is there something better for pipes that are more out in the open? Also, does painting the pipes a darker color help with keeping them warmer, or is that just a myth?
      • TinyTool
        • 357
        For exposed pipes along an outside wall, foam insulation is a solid starting point, but it might need a bit of reinforcement for outdoor use. Foam does a good job of reducing heat loss, but since it’s vulnerable to sun and weather damage, you should consider wrapping it with UV-resistant tape or a weatherproof jacket to make it last longer. If you live in an area with freezing temperatures, heating cables or heat tape are a great addition. These can be wrapped around the pipes to provide warmth and are often thermostatically controlled, so they’ll only turn on when needed.
        Another option for fully exposed pipes is using rigid pipe covers or insulated enclosures. These not only provide extra insulation but also protect the pipes from physical damage caused by harsh weather. As for painting the pipes a darker color, it’s more of a myth than a practical solution. While darker colors do absorb more heat, the effect is minimal and won’t significantly help in keeping the pipes warm during colder months. Your best bet is to focus on proper insulation and, if needed, supplemental heating to ensure the pipes stay protected.
        • Downaski
          • 409
          I just searched for heating tapes, and it looks like they’re powered by electricity. I’m actually looking for something that’s power-free. Is foam insulation the best option, or are there other alternatives?
          • TinyTool
            • 357
            Foam insulation is definitely one of the easiest and most effective power-free ways to protect pipes, but there are a few other options you can try. For example, you can use non-electric pipe wrap tape, like rubber or fiberglass, which works great when combined with foam insulation for extra protection. Another low-cost method is wrapping the pipes with burlap, old rags, or even blankets. Just make sure they stay dry because moisture can make things worse. There’s also heat-retaining paint, which isn’t a standalone solution but can boost the overall effectiveness of other insulation methods. For serious cold, combining a few of these approaches will give you the best results!
            • Downaski
              • 409
              Thank you for the detailed explanation!
