Leaky pipe inside a wall
  • Gardenboy
    • 334
    What’s the best way to identify a leaky pipe inside a wall? Are there any methods or tools to help detect a leak within the wall without tearing it open?
  • TinyTool
    • 357
    Hi! Detecting a leaky pipe inside a wall without tearing it open can be tricky, but there are several methods and tools that can help:
    1. Look for visible signs: Start by inspecting the wall for discoloration, water stains, bubbling paint, or peeling wallpaper. These are often the first signs of a hidden leak.
    2. Check for mold or mildew: A musty odor or visible mold on the wall surface can indicate prolonged moisture, suggesting a hidden leak.
    3. Use an infrared (thermal) camera: These cameras can detect temperature differences caused by moisture. A cold spot on the wall may indicate the presence of water.
    4. Moisture meter: This handheld device can measure the moisture content in your walls. High readings in specific areas can help pinpoint the location of a leak.
    5. Listen carefully: Sometimes, you can hear the sound of water dripping or flowing inside the wall, especially in quieter environments.
    6. Check your water meter: Turn off all faucets and water-using appliances, then monitor your water meter. If it continues to move, you likely have a leak somewhere.
    7. Inspect adjacent areas: If the wall leak is suspected, check ceilings, floors, or nearby walls for additional signs of water damage that could indicate the source.
    If you suspect a leak but can’t pinpoint the source, it might be time to call in a plumber who can use specialized equipment, like acoustic leak detectors or video inspection cameras, to find the problem with minimal disruption.
    • Gardenboy
      • 334
      Thanks for the helpful tips! I can actually see visible signs of leakage on the wall, like stains and peeling paint, but the tricky part is that the water has spread across a large section of the wall. It’s hard to figure out exactly where the pipe might be leaking. Do you think using a thermal camera or moisture meter would still help pinpoint the exact spot in a situation like this? Or would it be better to go straight to calling a plumber with specialized tools?
      • TinyTool
        • 357
        You’re welcome! If you can see visible signs like stains and peeling paint, that’s definitely a clue that water is spreading from somewhere behind the wall. A thermal camera or moisture meter can still be really useful in your situation. They’re great for narrowing down the general area where the leak might be. The thermal camera can help you spot temperature differences caused by water, while a moisture meter can give you more precise readings of dampness in different spots.
        That said, if the water has spread over a large section and it’s hard to zero in on the source, calling a plumber with specialized tools might save you time and effort. Tools like leak detection equipment or even infrared scanners designed for plumbing issues can pinpoint the exact spot more accurately.
        If you’re up for some DIY troubleshooting first, I’d suggest starting with the thermal camera or moisture meter to see if you can narrow it down before bringing in a pro. That way, you’ll have a better idea of what to expect.
        • Gardenboy
          • 334
          Thanks for the advice! The wall has also turned a bit greenish in some spots. Do you have any suggestions for cleaning that off?
          • TinyTool
            • 357
            If the wall has turned greenish in some spots, it’s likely due to mold or mildew caused by the persistent moisture from the pipe leak. To clean it off, start by protecting yourself, wear gloves, a mask, and safety goggles, as mold spores can be harmful when inhaled. Ensure the room is well-ventilated, or use a fan to keep air circulating.
            For cleaning, you can use a solution of equal parts white vinegar and water for mild stains, as vinegar is an effective natural mold remover. If the stains are more stubborn, a stronger bleach solution (one cup of bleach in a gallon of water) can help eliminate deeper mold growth. Gently scrub the affected areas with a sponge or soft brush, being careful not to damage the wall's surface. After cleaning, rinse with clean water and dry the wall thoroughly with a towel or fan.
            To prevent the issue from recurring, it’s crucial to address the root cause of the moisture, repairing the leak fully is key. Once the pipe is fixed, you might also consider applying a mold-resistant primer or waterproof paint to the wall to protect it from future damage. If the greenish stains return after cleaning, it could indicate that moisture is still seeping in somewhere, which may require further investigation. Let me know if you’d like more tips on managing this!
            • Gardenboy
              • 334
              Thanks for the detailed advice! I’m planning to address the leak soon, but I’m curious if there are any specific mold-resistant primers or waterproof paints you recommend for this kind of issue? Also, if the greenish stains come back, how would I go about identifying where the moisture is still coming from? I appreciate any further tips!
              • TinyTool
                • 357
                You're welcome! For mold-resistant primers, I'd recommend looking for products that are specifically designed to handle high moisture areas, such as those labeled for use in bathrooms or kitchens. Some trusted brands include Zinsser, which offers a mold-resistant primer, and Benjamin Moore’s Aura line, which has excellent mildew resistance. These primers will help block stains and prevent mold from growing back.
                As for waterproof paints, you want one that’s durable and resistant to both moisture and mildew. A good choice would be paints like Behr’s Premium Plus Ultra or Sherwin-Williams’ Duration, which are known for their water resistance and ability to withstand high humidity.
                If the greenish stains return after cleaning, it could indicate that moisture is still seeping in from the pipe or other sources. To pinpoint the exact location of the leak, you might consider using a moisture meter, which can help detect hidden dampness behind the wall. Another option is a thermal camera, which can reveal temperature differences caused by moisture. If these methods don’t work or the problem persists, it might be time to bring in a plumber with specialized equipment like leak detectors or infrared cameras to find the source without causing further damage to the wall.
                • Gardenboy
                  • 334
                  Thank you!
                  • Zeeshan786
                    • Nov 2026
                    That greenish discolouration is worth taking seriously, because it usually means moisture has been sitting in the wall for a while rather than just drying on the surface. Before repainting, I would make sure the leak is fully fixed and the wall cavity is dried out, since painting over damp plasterboard can trap the problem. If the affected area is large or the smell persists, getting help with mold remediation Herriman UT can be a sensible next step.
                    • dntreecareinc
                      • Oct 2026
                      • 7
                      One extra check before repainting is to make sure the wall is dry all the way through, not just on the surface, since a surface that feels dry can still hold moisture behind it.
