Water pressure issue
  • DarkKnight
    • 328
    Hello everyone! I've noticed that the water pressure in my bathroom fluctuates randomly throughout the day. There are no visible leaks, and the main valve is fully open. Could this be a pressure regulator issue, or is there something else I should check?
  • TinyTool
    • 357
    Hi there! It sounds like you're on the right track considering a pressure regulator issue. Fluctuating water pressure can definitely be caused by a faulty pressure regulator, especially if your home has one installed. However, it could also be related to issues like a partially clogged pipe or even a problem with the water supply itself. To better understand the situation, I'd recommend checking the pressure at multiple faucets to see if the fluctuations are isolated to one area or affecting the whole house. If it's just the bathroom, it could be a localized issue, like a valve or faucet problem. Also, is the fluctuation more noticeable at certain times of the day? That could help identify if it’s related to high water usage elsewhere in the house or neighborhood. If you're comfortable with it, testing the pressure at different points using a gauge might also give you a clearer idea of where the problem lies.
    • DarkKnight
      • 328
      Hi, TinyTool!
      I'm not sure if there's a pressure regulator installed, but I do have a water tank on my roof. As far as I can tell, the issue seems to be limited to the upper portion of the house, though I haven't checked thoroughly to confirm if it's affecting other areas as well. I also can't say for certain if it happens at specific times, but it seems to occur occasionally without any clear pattern. Do you think the rooftop tank could be a factor in this?
      • TinyTool
        • 357
        Since you have a rooftop water tank, that could definitely play a role in the pressure fluctuations. If the water level in the tank gets low at times, or if there's an issue with the inlet valve or air getting into the system, it might cause inconsistent pressure. Since it mainly affects the upper part of the house, checking the water level in the tank and ensuring the supply line is clear could be a good start. Also, if the tank refills automatically, a slow refill rate or partial blockage in the inlet pipe could contribute to the issue. If you get a chance to check other faucets, that might help narrow down whether it's just the upper floors or the whole house. Let us know what you find!
        • DarkKnight
          • 328
          I haven’t checked yet whether the issue affects the whole house or just the upper floor, but I’ll take a look at that and see if there’s a pattern. As for air getting trapped in the system, what’s the best way to check for that? Would opening all the faucets at once help flush out any air, or is there another method I should try? Also, if there’s air in the system, what could be causing it? Thanks for the insight, I’ll update once I’ve checked the rest of the house!
          • DarkKnight
            • 328
            Just an update, I confirmed that the issue is mostly affecting the upper floor.
            • TinyTool
              • 357
              Since the issue is mainly affecting the upper floor, your rooftop water tank is likely playing a role in the pressure fluctuations. One possible cause is air trapped in the pipes, which can lead to inconsistent water flow. A simple way to check for this is to open all the faucets in your home, starting from the lowest one and moving upward. If you hear sputtering or notice uneven water flow, air might be in the system. Air can get trapped if the water level in the tank gets too low, if there’s a small leak in the supply line allowing air to enter, or if the inlet valve isn’t working properly and causing irregular refilling. It’s also a good idea to check if the tank is filling at a steady rate and to inspect the inlet and outlet pipes for any blockages. If you have a pressure gauge, measuring the pressure at different points in the house can help determine if the issue is linked to the tank's supply. Try these steps and see if anything changes, and feel free to update us with what you find!
              • DarkKnight
                • 328
                Thanks, Tinytool.
                Can you please explain how to determine if there is a blockage? I mean how can I check that? Thanks!
                • TinyTool
                  • 357
                  Here’s a simple way to check for a blockage in the pipes, step by step:
                  Checking the Inlet Pipe (Water Coming In)
                  1. Turn off the water supply – Locate the valve that controls water going into the tank and shut it off.
                  2. Disconnect the pipe – If you're comfortable, unscrew the pipe where it connects to the tank.
                  3. Check if water flows – Briefly turn the valve back on (with the pipe disconnected) and see if water comes out. If it flows strongly, the pipe is clear. If it barely trickles or doesn’t flow, there may be a blockage.
                  4. Look inside the pipe – Some pipes have a small filter or screen at the end. If it’s dirty, clean it.
                  5. Flush it out – If needed, run some water through the pipe while it’s disconnected to clear any debris.
                  Checking the Outlet Pipe (Water Draining Out)
                  1. Observe drainage – If the tank is slow to empty or water isn’t flowing properly, the outlet pipe could be clogged.
                  2. Listen for weird sounds – Gurgling noises when draining may indicate a partial blockage.
                  3. Try a simple test – Use a long wire, a flexible plumbing snake, or a small stream of water to see if there’s any obstruction.
                  4. Use air or water pressure – If you suspect a minor clog, try running water or using a short burst of air to push it through.
                  If you’re not comfortable disconnecting pipes or if the blockage is serious, it’s best to call a plumber. They have the right tools to clear the pipes safely without causing damage.
                  • DarkKnight
                    • 328
                    That’s a really helpful guide! Honestly, this seems like a bit too much for me to handle on my own. I think it’s best to call in a plumber to make sure it’s done right. But it’s great to know the steps in case I ever want to try troubleshooting first!
