Epoxy Grout
  • Tomhanks
    • 193
    Epoxy Grout
    Hi all,
    I’m thinking about using epoxy grout to fix some worn grout between my tiles. Is this something that can be done as a DIY project, or is it better to call in a pro? Also, what kind of tools or materials would be needed for the job?
    Appreciate any advice!
  • Downaski
    • 409
    Hey!
    Yes, epoxy grout can definitely be a DIY project, but it’s a bit trickier to work with compared to regular grout. It sets faster and tends to be stickier, so it’s best to work in small sections and clean as you go. If you wait too long to wipe it off, it can be really hard to remove.
    You’ll need an epoxy grout kit (some include everything), a rubber grout float, a good sponge, lots of clean water, and some gloves since it can get a bit messy.
    If you're careful and follow the instructions closely, you should be fine. The key is taking your time and not rushing the cleanup part.
    • Tomhanks
      • 193
      Thanks, that helps a lot! One thing I’m wondering: how soon after applying the epoxy grout should I start wiping it off? Is there a time window I should aim for?
      Also, is there a particular sponge or cleaner that works best for cleanup, or just plain water?
      Appreciate the tips!​
      • Downaski
        • 409
        It is best to start wiping off epoxy grout within 10 to 15 minutes after application, as it begins to harden quickly. Working in small sections allows better control and helps avoid excess grout drying on the tile surface.
        For cleanup, use a grout sponge, ideally one made for epoxy, and plenty of clean water. Rinse the sponge frequently to prevent smearing. In case any haze remains after drying, a grout haze remover made for epoxy can be used.
        Following the manufacturer’s instructions for timing and cleanup is important for best results.
        • Tomhanks
          • 193
          Thanks, that’s helpful. If some epoxy grout haze gets left behind during cleanup, what’s the best way to remove it without damaging the tiles? Is there a point where it becomes too hardened to clean off easily?
          • Downaski
            • 409
            If some epoxy grout haze gets left behind, it’s best to deal with it as soon as possible. Within the first 24 hours, a damp sponge or cloth with warm water can sometimes take care of light haze. If it’s more stubborn, a haze remover specifically made for epoxy grout is a safer option than scrubbing hard or using harsh chemicals, which could damage the tiles. Once it fully hardens, usually after a day or two, it gets much tougher to remove, so the sooner you tackle it, the better.
            • Tomhanks
              • 193
              Thanks so much for all the help!
