Hi All,
I'm a new homeowner, my wife and I had our home built last year. It is a modular/doublewide sitting on a full concrete block basement, which sits on top of the ground because of a very high water table. (Less than 4 inches of the basement is below grade.) I don't have a problem with moisture coming up from the floor, that I have seen, but the 'flood zone' starts right across the street from me, about 30 feet.
We want to start finishing the basement into a living area, and are going to start with the bathroom. All of the drain pipes were put in before the slab was poured. The toliet flange is flush with the top of the slab, and the drain for the bathtub was blocked off with 2x4's when the poured the floor, and just has gravel by the pipe. There are several thin cracks in the slab, going all over the place.
My questions are these:
1) Should I wait to do anything until the floor stops cracking, or is a year long enough for settlement?
2)I want to put linoleum down as the flooring. After I seal the cracks that are there in the slab, should I seal the floor or use some other kind of moisture barrier?
3) For the concrete block walls, I'm planning on gluing blue foam board insulation to the wall, then using tap-con screws to attach treated 2x4 studs to the wall, over the insulation. Is this the correct way to put up an interior wall in a basement, or should I seal the walls first? Before we got gutters, moisture was seeping in on the walls and making the blocks darker, but now I have not noticed this except in one spot on the end of the house, away from where we are putting the bathroom.
4) I asked a guy at Lowes about this project, and he did not know any answers, but he did say that I should parge, of parch the walls with a thin layer of cement. Is he right, and would this seal the inside walls?
5) It appears that the floor mounds up at the toilet flange. I have not measured this, but it seems to be about 1/4th of an inch. How screwed does this make me?
Thanks for any help!
(hence expansion joints or cut lines in the concrete). Having said that, after a year as long as the cracks are not opening up wider you should be safe.
