glass block
  • wvguy
    Painting, Decks and Fences Moderator
    • Apr 2007
    • 72
    glass block
    Ok glass block . I am going to remove a window in the garage and replace it with glass block. What do you use inbetween the block? Any tips?
    thanks,
    JIM
    there was a blurb on the HGTv network from the Rock Guys about installing glass block.
    • glassblock
      • Dec 2009
      how to finish joints between glass blocks
      the 2 most popular methods to finish the joints between glass block windows and walls are mortar and silicone. The advantages and disadvantages of both methods are as follows:
      Question 2 – Is it best to purchase premade windows with mortar or silicone joints between the blocks? – Mortar and silicone joints each have their own advantages and disadvantages, but purchasing pre-made windows is almost always a cost savings vs. doing the project block by block.
      • Mortar Advantages – harder to break through, traditional masonry look, more variation in joint size
      • Silicone Advantages – all glass look, windows come out smaller in size, easy to clean.
