Power guns
  • OleBill
    • Aug 2007
    Power guns
    I hope this is in the right place It has come time for me to start using a power gun can anyone help deciper the lingo of this items for me I work on items like picture frames and small nic nak's
    thanks
    if what you are referring to is a brad nailer then ok. for picture frames you need to hold the corner steady when you glue it up and hold it together. an ANGLE CLAMP would be helpful. you can use DOWELS and glue to hold the corner together or A FINGER JOINT.
    • OleBill
      • Aug 2007
      power guns
      Im using dowl pins now but I figure if I can get some sort of nail gun This would make the process faster With the dowels and glue you have two areas of wait and see Is there a certaint type of braid nailer I will need Im a idiot with these new machines (glue-dowel pins-nails) is all I use by hand
        choice is yours. I use all Porter-Cable.
        • OleBill
          • Aug 2007
          Thanks a lot I will get one and check it out Again Thanks
