I have a dilemma, and need some advice. I have a bi-level home with full size basement windows (4x4). They are wood windows, and the sills are in bad condition due to moisture. They are in a concrete foundation. The grade on the home has sunken and needs to come up 3-5 inches where the windows are. When that happens, the sills will be covered by 2 inches of dirt. I know that can't happen.
My questions: I believe I may have two choices here. I can replace the windows with vinyl and add a well to each ($$$$!), or could I put in a smaller window (not so high so it would be above the grade)? If I change the size of the window, (they would still be at least the size of a regular basement window), how do I fill in the hole where the concrete was? Am I right to think it might be cheaper to replace with smaller windows (no wells)?
Help and advice would be much appreciated!!!!
