The spreader arms on the attic stairs in my house are bowed inwards and are getting worse everytime I open it up. They were installed before I moved into the house, so I'm not sure of the brand. Is it possible to find replacement arms or do I have to install an entire new stairs case?
Attic Stairs repair
just assuming the stairs were attacked by humidity and heat and they started curving, I would think the whole assembly should be replaced. once wood starts to warp in any given direction its almost impossible to stop it. be it a material fault or an engineering choice of materials, I wouldn't keep it. now its dangerous for anyone using it. it could collapse causing injury to the user. -
attic stairs repair
thanks for your reply...the wood is not bowed or warped, it is the steel arm that folds up and down...I think you're right I need to replace it...I was hoping not to replace the whole thing and just get parts...everything I've looked at online does not have partsComment
Hi, I'm currently having the same problem. I found attic replacement spreader arms at INDUSTRIAL LADDER online (cost around $30. for a pair) Customer Service said if they do not fit then they can be sent back and they will credit everything but the shipping costs. I couldn't find them in any stores so I thought it was worth taking a chance as the picture looked exactly like my attic stairs. Good luck!!Comment
