Which window type is best for energy efficiency?
Window replacement
For the best energy efficiency, you'll want to look at windows that combine several features designed to keep your home comfortable and reduce energy bills. Triple-pane windows are excellent because they offer top-notch insulation with their three layers of glass and two insulating spaces. Low-E (low-emissivity) windows are also a great choice since they have a special coating that helps keep heat in or out, depending on the season. Gas-filled windows with argon or krypton between the panes further enhance insulation. Vinyl and fiberglass frames are both energy-efficient options, as they help minimize heat transfer and prevent air leaks. Always check for the ENERGY STAR label to ensure you’re getting a product that meets high energy efficiency standards.
Hope this helps!
